Concrete on the car - How to remove?
Old Aug 1, 2007 | 08:45 AM
eddy121's Avatar
Default Concrete on the car - How to remove?
Hi All,
I have recently driven trough a puddle of what I taught mud, however it turned out to be fresh concrete from a local building site. As I assumed it was mud I did not do anything about it immediately and now this has hardened on the car. It looks bad! Really bad!
It is all over the grill and front fogs and light as well as behind every wheel. Do you have any suggestions as how to remove this? I have tried some sprays for tarmac but that did not do a trick.
Any suggestions? Thank you in advance for your help!
Regards,
Eddy121
Old Aug 1, 2007 | 09:08 AM
Too Tall's Avatar
Default RE: Concrete on the car - How to remove?
Ouch that sounds painful, I havent had to deal with that yet. After a quick google search I found this
http://topoftheline.com/cement-concr...over-auto.html
I haven't used it or anything but it sounds like your ready to try just about anything short ofhammeringthe crap off. Hope that helps.
Old Aug 1, 2007 | 09:20 AM
ironman's Avatar
Its that or a sledge hammer
Old Aug 1, 2007 | 10:27 AM
acetrebo's Avatar
On the grill, and inside the wheel wells,you can chip it off with soemthing, a screw driver and hammer, or chisel.
Old Aug 2, 2007 | 10:34 AM
eddy121's Avatar
Just seen also they suggest to use household vinegar and/or muriatic acid, so I guess I will try Vinegar first, but if that does not work I will try anything I can get my hands on.
Thanks for all suggestions, I will let you know results once I tried few options.
Old Aug 2, 2007 | 10:42 AM
oklahoma audi's Avatar
Lowes has a muriatic acid wash for concrete and mortar for brick. It has instructions for mixing with so many parts of water. Comes right off. I should know, I'm a home builder! Get concrete on my work trucks all the time. You'll need to get a new wax job afterwards, because the acid can dull the wax finish, but shouldn't hurt the paint or clearcoat.
Old Aug 13, 2007 | 07:03 AM
eddy121's Avatar
Hey all, just to update. Tried household vinegar and it WORKS!!!!!! It takes some time and effort but it works.
Thanks for support but I can say this problem solved!
Old Aug 13, 2007 | 07:36 AM
CLX's Avatar
CLX
Zombie Defense Force
Sweet, household chemicals FTW! Just like the baking soda on your battery terminals to clean them!
Old Aug 13, 2007 | 04:09 PM
zeven13's Avatar
FYI - If you ever use muriatic acid, keep it away from anything metallic. It will rust quickly if contacted. Simply storing pure muriatic acid in the same room as metals can cause them to rust.
atlasequipments
Dec 3, 2012 01:33 AM
liquidcool
Aug 30, 2011 08:39 PM
rb20cory
Aug 14, 2010 02:14 PM
kevace1
Mar 11, 2010 12:23 AM
A4 Effort
Apr 8, 2008 07:10 PM
