Convert a 1.8 non turbo to turbo ???
Old Mar 8, 2007 | 06:40 AM
speeedy's Avatar
Default Convert a 1.8 non turbo to turbo ???
Hey guys i have a Audi A4 1.8 litre non turbo and wana know what would be involved in converting it to a turbo ? Is it just a simple get the parts off a turbo model and they bolt straight on ? Anyone info would be helpful
Old Mar 8, 2007 | 07:39 AM
techbod's Avatar
Default RE: Convert a 1.8 non turbo to turbo ???
im sure they do bolt on kits for that
http://images.google.co.uk/images?hl...kits&gbv=2
Old Mar 8, 2007 | 12:09 PM
sean1.8t's Avatar
not too familiar with the N/A 1.8 but im sure it's as simple as just swapping on the parts from a 1.8t
but the true problems would lie in the compression ratio, im sure yours is higher than a 1.8t's so you would need to go about changing that if you're wanting to run a decent amount of boost.. a couple of choices for going about that..
and then there is the software problem. i don't even want to go into that
Old Mar 8, 2007 | 03:55 PM
Ford2Audi6's Avatar
^ +1 on the compression, you definitely need to change it and make it lower. And retuning the ecu to allow for those changes will be hard too.
Old Mar 8, 2007 | 04:04 PM
96audia4's Avatar
N/A 1.8? Is that a european thing?
Old Mar 8, 2007 | 08:26 PM
04a4's Avatar
Couldn't imagine a 1.8 without a turbo. Didn't even know they sold them like that, where did it come from?
Old Mar 8, 2007 | 08:45 PM
A4Rollin's Avatar
yah man, when or where did they make the n/a 1.8??? Never heard of that before
Old Mar 8, 2007 | 08:57 PM
Flip's Avatar
The turbo manifold and turbo should bolt right on. Thenyou will need to look into fuel delivery. I don't know what size fuel pump or injectors are in the 1.8 non turbo but they are probably going to need to be upgraded to a bigger size tocompensate for the extra air that the turbo will be adding.
Old Mar 8, 2007 | 09:00 PM
04a4's Avatar
to me it sounds like it is just worth buying a 1.8 that already has a turbo, sell the N/A and upgrade from there imo
Old Mar 9, 2007 | 12:14 AM
Belligerenceā„¢'s Avatar
I'd hate to think how slow a N/A 1.8 is, cause my stock 1.8T is pretty damn slow.
rnbguy
Sep 10, 2009 12:47 AM
speeedy
Mar 8, 2007 09:10 PM
mr V8
18
Jun 23, 2006 03:21 AM
