Converting from DBW to Cable
Old Jan 5, 2006 | 01:51 AM
_Adrian_'s Avatar
Default Converting from DBW to Cable
like topic saiz.
has anyone done it without major major mods ??? ( standalone doesnt count )
Also i am planing on chipping the car ( 2000 1.8TQM )
Old Jan 5, 2006 | 02:28 AM
trailboss's Avatar
Default RE: Converting from DBW to Cable
Why? You aren't going to get any performance gains and i really dont think you can unless you got a new ecu because your ecu now controls your TB and obviously the gas pedal.
Old Jan 5, 2006 | 02:35 AM
_Adrian_'s Avatar
the reson is that in the past 5 or 6 years that i've been workin with DBW systems all of them were a pain in the ***!
failing butterfly motors, tps issues galore, i mean the whole concept to me is taboo
i mean what was the point of introducing DBW???
more for us mechanics to fix (Pluss im getting some weird codes relating to the DWB system so i think its time to convert)
Old Jan 5, 2006 | 02:50 AM
trailboss's Avatar
like what kinda codes, you own a VAG.
Old Jan 5, 2006 | 02:55 AM
Yuikio's Avatar
I'm pretty sure you don't need standalone...just an ECU and cluster of the year of the car whose nDBW hardware you're stealing. Which includes, IIRC, cable, TB, pedal cluster, probably some wiring ****...
Actually, I have little to no idea what I'm talking about. But i don't think you need standalone.
Old Jan 5, 2006 | 10:20 AM
_Adrian_'s Avatar
ORIGINAL: trailboss
Not a VAG but i just recently purchased a Snap-On Solus (Scanner) and Snap-On Vantage Pro (2Ch. Lab Scope)
I forget what the code numbers were but i cleared hopping they wont return.
I think they were something Like... (long day at work)
TPS reference signal out of range (high)
I will check the TPS today with the Vantage and see if I find bad spots on it
Old Jan 5, 2006 | 03:01 PM
goldenchild's Avatar
u would need standalone if u have the variable valve timing bc a diff ecu will probally f **** up. u can buy the conversion kit from 034efi so id ask them instead of askin here were no one would have a clue u know
shuggy81
Jun 19, 2013 12:38 PM
A4Guy23
Oct 11, 2008 03:03 PM
mopar_350
Oct 2, 2008 11:04 AM
jduplooy
Jun 2, 2008 01:15 PM
AkTT
May 18, 2006 09:32 PM
