coolant
Old Jan 19, 2007 | 05:17 PM
mrdb85's Avatar
Default coolant
i recently changed my radiator, water pump, and thermostat. then i had to flush my system a few times becasue the heater core was clogged and i wasnt getting heat. so i finally got it all cleaned out, and i filled it back up with the red coolant like your supposed to. that was 2 months ago and now my coolant has turned clear almost like cloudy white water. shouldnt it remain red? Any ideas or recommendations??
Old Jan 19, 2007 | 05:59 PM
CRAZYHAWK's Avatar
Default RE: coolant
You probably used an antifreeze different from G-12. Flush again
and use either G-12 or universal global yellow.
Old Jan 26, 2007 | 04:38 PM
mrdb85's Avatar
Default RE: coolant
no i definitley used g12, i bought it from the dealer. could i possibly have a bad oil cooler???
Old Jan 28, 2007 | 12:42 PM
david9999's Avatar
Default RE: coolant
Remove some coolant and see if it is cloudy/opaque
Cioffie
May 19, 2013 10:24 PM
GLD
Dec 6, 2008 05:22 PM
Ph3N0m
Oct 21, 2008 12:58 PM
less_of_me
May 2, 2007 03:29 AM
