Coolant Indicator on every morning
Old Jan 9, 2008 | 05:40 PM
rcil's Avatar
Member
Default Coolant Indicator on every morning
I have 2001 A4 Quattro with 71k miles on it. The coolant indicator comes up every morning when I start my car and goes off in couple of minutes. The coolant indicator shows in the middle and car runs smooth. I am very new to the repairs and I have no idea whether the coolant is low or what type of coolant I have to use and where to buy.
Is it ok to top it off or do you guys recommend flushing it all out and re-filling. Any ideas how much would it cost to flush out and re-fill and what parts do we need? Thanks and appreciate all the inputs.
Thanks,
RCil
Old Jan 9, 2008 | 05:58 PM
auditech79's Avatar
Default RE: Coolant Indicator on every morning
You need to buy G12 coolant only, go to the dealer to get it. If you open the hood and look at the coolant resivior it will have a max mark, thats what the level should be at when the engine is hot. If its not there top off the system and check for leaks. If its full and light is still going off then you need a new resivior which has the sensor built in.
Old Jan 9, 2008 | 06:51 PM
rcil's Avatar
Member
Thanks very much for your quick response. I will check the coolant level and buy G12 from the dealer. Hope I don't need to flush and refill.
Thanks,
RCil
tofast2belast
Mar 30, 2013 02:16 PM
v6cab
Aug 21, 2011 07:27 AM
piledriver
Aug 2, 2007 03:53 PM
sptriple
Nov 29, 2006 12:36 AM
