Coolant leak from coolant flange
Old Apr 29, 2007 | 08:04 PM
less_of_me's Avatar
Default Coolant leak from coolant flange
Hey guys, I searched the boards, but couldn't find anything specific on this subject. I was wondering if I would have to drain the coolant to replace the coolant flange. I assume I need to replace that at least.
From appearance, it looks like coolant is leaking out of where the coolant temp sensor actually goes in. I can see dryed up coolant underneath where it is at and the coolant has gotten all crusty around the sensor. Do I need to replace the whole flange, or is there some sort of gasket or something.
Old Apr 29, 2007 | 08:07 PM
onepoint8tee's Avatar
Default RE: Coolant leak from coolant flange
There is a rubber 0 ring that sits between the sensor and the flange. I would try replacing the 0 ring and/or sensor before doing anything else. Since your taking the sensor out to put in a new 0 ring, you might as well just replace the sensor too if your car is more than 5 years old. Its a common part to fail with these engines anyway.
Old Apr 29, 2007 | 08:28 PM
less_of_me's Avatar
When I took out the coolant temp sensor yesterday, there was no rubber ring.....thanks again onepoint8tee
Old Apr 29, 2007 | 08:38 PM
ORIGINAL: less_of_me
Are you SURE? Sometimes they get stuck down in the flange. Take it out again and stick your finger down in there.
Old Apr 29, 2007 | 08:56 PM
less_of_me's Avatar
alright...I will try that later, when the car has cooled down a bit and let ya know what I find.
Old May 1, 2007 | 08:19 PM
mrmackey's Avatar
I have a leak coming from the fiange on my wifes 02 A4 1.8.Do you know what the cost is to replace the flange?
Old May 1, 2007 | 08:40 PM
less_of_me's Avatar
Ok, so I did find that ring you were talking about, and I reset it back on the CTS. It doesn't appear to be leaking out of that area any more, (and I stress appear) but I did find some crusted up g12 where the flange meets that black metal pipe (forgive my lack of the correct word). So I am going to try and tighten the bolts where the flange meets that metal pipe and also where it conects to the engine.
I was at the audi dealership today, and they sell the flange for 31.00 bucks. In case I need to get the flange, does anybody know of a better website to pick one up?
Old May 1, 2007 | 08:47 PM
chitownA4's Avatar
at the dealer its about a $600 job...i made that $600 mistake..$500 for labor...get outta here
Old May 1, 2007 | 08:52 PM
less_of_me's Avatar
Dang...more than 500 even. I was wondering if you need to drain all the coolant before you change the flange, or can you just raise the rear of the car and loose a small amount of g12?
Old May 1, 2007 | 09:52 PM
mrmackey's Avatar
I got a quote here in Ct. from 300 to 400 .That was over the phone who knows what they will whack you with once they have it apart.
