couple of codes
Old Nov 21, 2007 | 10:16 PM
hiwords's Avatar
Default couple of codes
p0159 and p1602
would a exhaust leak trigger the p0159? the leak is not small but not huge either.
no idea bout the other one though. wut is at terminal 30? could a HID do that? the first one was deleted b4 but came back today. the other one is a new one. hopefully it doesn't come back.
Old Nov 22, 2007 | 06:46 PM
hiwords's Avatar
Default RE: couple of codes
bump
Old Nov 23, 2007 | 01:51 PM
hiwords's Avatar
bump again
Old Nov 23, 2007 | 09:19 PM
hiwords's Avatar
i guess i'll bump it one more time?
Old Nov 23, 2007 | 09:28 PM
auditech79's Avatar
P1602 doesn't exist on my DTC data chart.
P0159 is a slow response fault for the after cat O2 sensor, its probably a faulty sensor.
Old Nov 23, 2007 | 10:16 PM
hiwords's Avatar
i'll scan it again. the bentley manual has it as power supply B+ terminal 30 low voltage. i'll scan it again when the light comes back.
Old Nov 23, 2007 | 11:45 PM
auditech79's Avatar
ORIGINAL: hiwords
Oh, thats not an engine related fault thats why. Its a fault code sometimes thrown when the battery is dis-connected or a relay stuck. Its nothing to worry about if everything is working, it won't cause a check engine light, but the other fault code will.
Old Nov 23, 2007 | 11:50 PM
hiwords's Avatar
ooo ty. will an exhaust leak on the flex pipe throw the p0159?
Old Nov 24, 2007 | 12:01 AM
auditech79's Avatar
Absolutely not, but you should get that fixed anyway, its not good for the engine.
Old Nov 24, 2007 | 12:06 AM
hiwords's Avatar
course i will. if there's anything wrong wid ma baby im gona fix it. no debate bout dat.
Jerzyboy973
Jun 14, 2009 04:32 PM
richrich
Apr 15, 2008 11:19 PM
jojoampt
Feb 26, 2008 12:31 AM
less_of_me
Jun 10, 2007 11:08 PM
Trey25
Nov 27, 2006 12:16 AM
