It cranks but doesn't start
Old Nov 20, 2007 | 03:16 PM
  #21
aRIf's Avatar
Default RE: It cranks but doesn't start
I installed the new ICM but still same [:@]
What else could it be? Am I missing something here?
Is there any other fuses other than the side of the driver door?
Old Nov 20, 2007 | 03:23 PM
  #22
hiwords's Avatar
u have no spark in any plug?
Old Nov 20, 2007 | 03:30 PM
  #23
aRIf's Avatar
I only checked 1st one. I dont think I have any spark on others because rpm does not even move at all nor I dont see anything blowing in the engine.
no exhaust sound or anything.
Old Nov 20, 2007 | 06:57 PM
  #24
auditech79's Avatar
There are the main fuses next to the ecm that will cause this problem.
Old Nov 20, 2007 | 07:13 PM
  #25
aRIf's Avatar
you mean these?
Old Nov 20, 2007 | 07:16 PM
  #26
99A4NOW's Avatar
So you had fowled spark plugs but you didn't replace them? And you didn't have any misfire codes but everyone thought it was ICM? What else am I missing here?
Take the spark plugs out,pull the fuel pump fuse, release the fuel pressure,and turn the car over a few times. Let the plugs out for about a half hour while you go buy new spark plugs. When you get back put the new plugs in and replace the fuse for the fuel pump. Turn the Ignition key on for about 30 seconds and then try to crank it.
Let me know what happens.
Old Nov 20, 2007 | 07:17 PM
  #27
auditech79's Avatar
LOL, no thats the O2 connectors, engine speed sensor connector, and knock sensor connector.
You have to open up the ecm box, if those fuses are ok replace the engine speed or crank sensor.
Old Nov 20, 2007 | 07:34 PM
  #28
hiwords's Avatar
rn't those like the abs, brake wear, and 02 sensor harnesses?
Old Nov 20, 2007 | 07:36 PM
  #29
aRIf's Avatar
am i getting closer? where is it? or is it in the ECU itself?
  #30
auditech79's Avatar
ORIGINAL: hiwords
Ummm no. Both O2 sensor connectors, crank sensor, knock sensor, and maybe something for the abs depending on what year A4, but the brake wear harness goes directly to the clutster, its a simple circuit.
