It cranks but doesn't start
Old Nov 21, 2007 | 10:45 AM
  #41
hiwords's Avatar
Default RE: It cranks but doesn't start
http://cgi.ebay.com/ebaymotors/VW-Au...spagenameZWD1V
found that for u just in case there aren't any in ur area. it's from florida so u'll get it by like monday or tuesday. i guess this would be ur last resort cuz it's expensive as hell too
Old Nov 21, 2007 | 11:39 AM
  #42
aRIf's Avatar
I'm ordering from ecartoys right now.
Old Nov 21, 2007 | 05:28 PM
  #43
99A4NOW's Avatar
hmm, this part is faulty but it doesn't throw a code? That would seem strange to me....
No way to check this before throwing more money at parts trying to guess what's wrong?
Old Nov 21, 2007 | 06:04 PM
  #44
auditech79's Avatar
ORIGINAL: 99A4NOW
Crank sensors as well as ECT sensors almost never throw a fault code when they go bad, it depends on what is wrong with it, it will only throw a fault for both if the wire is cutt or open.
Figures there isn't a fuse next to the ECM, audi changes the damn design every fvckin year!!!![:@]
The crank sensor should take care of the problem, assuming you did pull off the fuel line to the motor and cranked it to see if fuel was coming out.
Old Nov 21, 2007 | 06:27 PM
  #45
aRIf's Avatar
I know there is fuel because;
-plugs are flooded
-I have fuel pressure gauge
Old Nov 21, 2007 | 06:49 PM
  #46
auditech79's Avatar
Then you should be golden with the crank sensor, i wish you had an oscilliscope but im sure it will fix it.
Old Nov 21, 2007 | 06:52 PM
  #47
aRIf's Avatar
Yeah I keep my finger crossed. Hoe it will fix the problem.
Old Nov 21, 2007 | 08:29 PM
  #48
99A4NOW's Avatar
So what kind of signal will a crank sensor give you? Square wave, right? I would think a logic probe would be able to tell you if you have any signal from it. I'm not tech certified, but I've been around cars a while. I've tested many crank sensors in other cars with a simple logic probe, never had any trouble doing it that way. How much was this sensor?
Old Nov 21, 2007 | 08:45 PM
  #49
aRIf's Avatar
I paid $130 including $38 over night charge. It's $132 at dealer. I've got it at ecartoys.com
Old Nov 21, 2007 | 09:09 PM
  #50
aRIf's Avatar
Dont ask me how but car ıs running right now [&:]
I want to crank it so I can get some vag com reading and it started.
