Cruise...
This is my cruise control computer. Solders all look fine but there is one spot I don't understand. In this photo, the brown block is the connector. The first connections above that look like they might want to be connected but aren't. I don't know sh't about boards so this its hard for me to tell, should these be connected? Its the 5 connections parallel to the brown connector, the first closest to the connector. If these are ok the problem must be in my switch.
[IMG]local://upfiles/25169/DCEB6FC1E9354B44AFB90DB27E3F87E0.jpg[/IMG]
No, you don't need to create any new connections, the problem is just that those blobs get little cracks in them. When I took mine out, I couldn't see any cracks or anything obvious to indicate a problem so the heat gun just tightened all of those little connections right up and sealed the cracks that I couldn't see. I think probably the heat gun is the best way to go instead of having to add flux or risk toasting something with a soldering iron.
A4 the Quattro
Mar 16, 2006 07:07 PM
