cruise control?
Old Mar 29, 2007 | 01:59 PM
wootang71's Avatar
Default cruise control?
i just bought a 2000 1.8 avant manual, and when i was test driving it, i noticed the cruise control didn't work. with electricals, the first thing i checked was the fuse box, and indeed there wasn't a fuse in the cruise control spot. however, when i DID put a fuse in, it just didn't fit right. it was loose. upon further inspection, i can't see any metal connectors in the cruise control fuse slot at all! so before i start taking things apart i'm wondering (since my car didn't come with an owner's manual, and this is my 1st audi): did cruise control come standard on 2000 a4's? is it possible for the connectors to be pushed THROUGH the fuse box? could the fuse map be incorrect? any insight would be great since i'm a big fan of cruise control.
Old Mar 29, 2007 | 02:13 PM
akielb's Avatar
Default RE: cruise control?
Common problem - search and you will find your answer
cruise control module?
cruise control stalk connectors?
Old Mar 29, 2007 | 02:35 PM
SacTown_Vlad's Avatar
1) fuse map on fuse box should be correct one, unless some replaced cover (just guessing) .
2) it's standard on 2000 a4
3) it would be really hard to push connectors out off fuse box.
Old Mar 29, 2007 | 09:08 PM
turbo kraut's Avatar
Tech Guru
mine is the exact same way
cruise no worky for me either
but i took it to the mechanic and he got the numbers to change on his computer(vag)..... he said it was my cruise stalk
Old Mar 30, 2007 | 12:23 AM
wootang71's Avatar
cool, thanks for the hints. but i'm not gonna get crazy on this until i can rule out the simplest item: the fuse box. i'm STILL wondering why there aren't any electrodes in the #11 spot! do they fall out sometimes? i'd love this to be a 2 cent fix, 'cause i love using cruise control. helps avoid speeding tix.
Old May 22, 2007 | 08:59 AM
dpbklyn's Avatar
I am having a similar problem with my "new" '98 2.8 and Ialso looked at thefusebox first. It seemsthat that spot in the fuse panel is reserved for the CC on AUTOMATIC trannies. mine is manual.
I am also having a problem with the "buzzer". when the seatbeltws arent fastened, or when the door is open in thekey in the ignition, it doesnt buzz. there is no fuse for that, and I examined EVERY fuse in the panel--all were OK. am I missing something? Are these problems related?
Thank you in advance for any help!
dp
chooch628
Sep 5, 2007 03:32 AM
JDriver2
Jul 10, 2006 11:16 PM
A4 the Quattro
Mar 16, 2006 07:07 PM
