crying day!
Old Dec 27, 2006 | 02:00 AM
flyscopio's Avatar
Default crying day!
I bought my A4 99, 2.8 quattro one week before.
And the day before yesterday the check engine light was on. Autozone check showed the code of P0102(The PCM determined that the mass air flow input is lower than expected for the current engine operating conditions.)
and P1857 ( Transmission transfer case contact plate 'c' short circuit tobattery ).
They told me I should replace the MAF sensorfor P0102 and they did know about the P1857.
Amazingly, after I replaced the air filter but not MAF sensor ($216!!!), the engine light went off.
And it was off this morning. However, this afternoon, I suddenly found that the engine light turn on again!!! And it showed the same code P0102 and P1857!!!!
I have another problem that is do I need to change the engine oil and transmission oil? If do, which oil should I choose and where I should go? Also how much usually it costs?
Thank you for your patience and help for a newbie.
Old Dec 27, 2006 | 02:04 AM
18T's Avatar
18T
Default RE: crying day!
MAF should be covered under warranty. its emissions.
and just go get an oil change at the dealer. its not THAT expensive.
Old Dec 27, 2006 | 02:05 AM
unorthodoxa4's Avatar
i have no idea if you need to change your fluids, but i would suggest doing it yourself if you do. theres no bigger waste of money IMO then getting someone else to change your oil.
also, my check engine light went on last night, exactly 1 week after i purchased the car, im terrified
Old Dec 27, 2006 | 02:06 AM
tractioncontrol's Avatar
Try cleaning the MAF.
Old Dec 27, 2006 | 02:07 AM
Amze's Avatar
I got my oil changed at kwik lube, they did an awsome job. It was 59$ total for the best synthetic oil, very easy and simple. I'll go back there again.
Old Dec 27, 2006 | 02:11 AM
18T's Avatar
18T
just got to the damn dealer and ivestigate. if your CEL is on and its not blinking then youre okay. dont have to freak out you can drive. its just telling you its emissions related.
Old Dec 27, 2006 | 01:57 PM
Pson's Avatar
ORIGINAL: Amze
Hole **** man......DIY they don't know how to put your skid plate on and crap you could buy gold and put it in there for cheaper. The V6 is the best oil change your ever going to get.
Old Dec 28, 2006 | 05:05 PM
toaster's Avatar
my audi dealership costs under 50 to get an oil change...no other place i'd even consider taking my car too.
Old Dec 28, 2006 | 05:13 PM
onepoint8tee's Avatar
I dont understand a $50 oil change from the dealer??? Any quality VW 502.x spec oil costs close to $5 a quart. 4+ qts.=$20min.and the OEM oil filter from the dealer is about $13. So are you telling me the DEALER is only charging roughly $17 in labor for this service? Thats impressive.
ImTheDevil's Avatar
Yep, clean the contacts on the connector. This is starting to sound like a recording for me lately LOL, but I'm not kidding - I think sometimes people don't know how many idiosyncrasies and freakish behaviors can be cured or eased by doing this. It's worth the $6 and the 45 minutes' time to clean all the contacts you can find in the engine bay.
qqqq898
Nov 21, 2012 05:42 PM
jnbsmom1969
May 31, 2012 01:42 AM
guyjusthere
Nov 25, 2006 12:10 AM
