curing a vibrating number plate? :-S
Old Aug 6, 2006 | 09:24 AM
Adyballard's Avatar
Default curing a vibrating number plate? :-S
I have just put a 3000W pioneer sub in my boot and sounds absolutly emmense until you shut the boot and the number plate starts vibrating like a B****. Any cheap ideas on how i can cure this? i have already tried double sided sticky tape and it lasted about 3 days! cheers
Old Aug 6, 2006 | 11:18 AM
david9999's Avatar
Default RE: curing a vibrating number plate? :-S
From an old fart, turn the volume down
You might want to try some rubber grommets behind the plate.
Old Aug 6, 2006 | 12:42 PM
techbod's Avatar
from another old fart get a plastic number plate and glue it on
Old Aug 6, 2006 | 12:51 PM
jliu's Avatar
I used to use sponge (just like the one you wash your car with..) and cut it one inch thick, and put it between your plate and bumper, coz the sponge absorbs the vibe, so it works like a charm.
Old Aug 6, 2006 | 01:23 PM
onepoint8tee's Avatar
"Boot"??? "Number Plate"??? You mean trunk and license plate right??? They make stuff called dynomat that is used for insulating areas of the car that vibrate with monster setups ike yours. But from the way you are describing these parts on your car, they may not carry this stuff in the part of the world you live in... ?? Im sure you could just rig something up. Put a piece of cardbord behind your plate.
Old Aug 6, 2006 | 01:38 PM
germancarmaniac's Avatar
ive got two 12 inc audiobahns and the only way i could get "everything" to stop vibrating is lots and lots of dynomat extreme.
Old Aug 6, 2006 | 04:06 PM
evoic's Avatar
Sponge.
If the bass is extreme, fold a kitchen hand towel and stuff it behind the plate.
Old Aug 6, 2006 | 04:18 PM
techbod's Avatar
ahh you have those metal plates there then??
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
put on the rear of the plate its like rubber when hard or you could get some of that black stuff they bond windshields with and its the best because its rubber
Old Aug 6, 2006 | 04:27 PM
BFlan2001's Avatar
dynamat is the only way to get rid of it...i also removed all the metal hardware on the trunk...my license plate is velcroed on
Old Aug 6, 2006 | 04:36 PM
techbod's Avatar
dynamite that's a little harsh lol opps you said Dynamat j/k
