Custom Downpipe
Old Apr 23, 2007 | 01:01 PM
AudiTurbo's Avatar
Default Custom Downpipe
Ok well im trying to get some idea from people on how hard it is to make a custom downpipe. My flexpipe is blown out, and I want to just got ahead and replace it with a bigger downpipe. Can i make a 2.5 inch dp, and still run it on stock cat and exhaust? and if I get a bigger cat and exhaust will it still work. I just want to get a dp for now, because im going to trade for a s4 soon....How hard is it going to be, and what is a good price range?
Old Apr 23, 2007 | 01:21 PM
SacTown_Vlad's Avatar
Default RE: Custom Downpipe
talk to your local exhaust shop for custom work… but I would get original part from junk yard, it would cost you less and u wont see much performance running on stock cat and exhaust.
Old Apr 23, 2007 | 01:28 PM
AudiTurbo's Avatar
Yeah, but I was going to go ahead and make it bigger just in-case I keep the car...
Old Apr 23, 2007 | 01:34 PM
A4speed's Avatar
techtonics.com has high flow cats and downpipes that are 2.5
Old Apr 23, 2007 | 01:41 PM
AudiTurbo's Avatar
ORIGINAL: A4speed
Will the dowpipe fit a stock exhaust though?
Old Apr 23, 2007 | 02:06 PM
Soley4pres's Avatar
yes it should .. it will need to be welded on ...the dp and high flow cat will bolt up nice gains and quicker turbo spool ..the dp may have to be welded on to your existing stock exhaust but a exhaust shop should do the install and it wouldnt cost very much
Old Apr 23, 2007 | 03:38 PM
AudiTurbo's Avatar
ok thanks...should I even worry about the custom then, or just buy it and have it put on?
Old Apr 23, 2007 | 03:56 PM
A4speed's Avatar
Well, I wouldn't worry about the custom job. Cat's use to be $6-700 for A4 until techtonics came out with theres for $295. So it's a way good deal.
Old Apr 23, 2007 | 03:57 PM
A4speed's Avatar
your stock exhaust is 2, so you'd have to have a piece welded on from the downpipe to your normal piping.
Jchockey100
May 2, 2012 11:34 AM
mattrazzo
Feb 20, 2011 03:44 PM
FattieJayMack
Jun 18, 2009 12:17 PM
deephouse
Apr 25, 2008 04:40 PM
nvus1too
Mar 25, 2007 02:39 AM
