Cylinder 2 misfire....please help me:-(
Old Mar 29, 2007 | 08:47 AM
x1rider's Avatar
Default RE: Cylinder 2 misfire....please help me:-(
I bought the car with an APR chip, so that came to my mind. Any ideas?
With the APR chip make sure the plugs are gapped properly. If they are gapped too wide, the increased boost pressure can snuff the spark, causing some misfires.
Old Mar 29, 2007 | 09:35 AM
david9999's Avatar
CYL 2 misfire usually turns out to the the ignition control module.
Old Mar 29, 2007 | 12:57 PM
oh1a4's Avatar
if you get repeated cyl 2 only after changing plugs and coilpack, i agree with the icm people.
Old Mar 29, 2007 | 01:17 PM
FASTER's Avatar
Tech Slut
im not tryna be an *** but... make sure ur actually changing ur coilpack on cylinder 2... i had a cylinder 1 misfire so i swapped packs from cylinder 1 to cylinder 2 n it came back with a c2 misfire... cylinder 1 is closest to the front of the car and they go back in order. but yea check out that icm
Old Mar 30, 2007 | 06:16 PM
littledude19's Avatar
Member
Yeah i just had to change my Engine Control Unit a month ago. It is also a 1998. I can almost guarantee that is the problem.
Old Jun 30, 2023 | 05:49 PM
Mrpotpal's Avatar
Default Misfire
I have a 2001 audi a4 1.8t that has a misfire on cylinder 2&3. I have installed new coils, injectors, plugs and no change. It's always when first starting. Can anyone help. I have noticed that people have mentioned the icm but I can find it. When I bought the car years ago the stock air box had been removed so I can not find it.
help please
Russ Heinrichs
Aug 18, 2021 12:39 PM
and b
Feb 10, 2014 11:52 AM
ThePizza
Jul 23, 2008 05:16 PM
ricky0323
Feb 29, 2008 01:35 PM
