Damn ... ofset problem what shoul I do ?
Old Feb 23, 2006 | 09:35 AM
prodrive's Avatar
Default Damn ... ofset problem what shoul I do ?
Hi guys .. I am going to buy coilover for 99 B5 but the problem is my BBS wheels ofset ,they are 32 insted of 35 so if I lower the car the wheels will rub to the fenders.I searched for the parts for camber adjustment but I found that they are only for front side.Can I widen u the fenders without bodywork and paint ? opinions plz.
Old Feb 23, 2006 | 01:44 PM
BFlan2001's Avatar
Default RE: Damn ... ofset problem what shoul I do ?
you can roll your fenders with a fender roller...some websites rent them and i believe some autozones also have loner tools that you can use for free...a 3mm difference shouldn't be a problem though...it depends on how wide your wheels are...i went from a 35mm to a 45mm offset, but it still rides fine because the wheels are much wider
Old Feb 23, 2006 | 03:47 PM
prodrive's Avatar
Thanx..bentframe BTW ,are you still selling your 3 spoke steering wheel (w/airbag) ? I have 225/40/18's though...4 mm' will be enough for me. in worst case I will lower as I can and throw some stiffer sways..
Old Feb 23, 2006 | 05:27 PM
techbod's Avatar
rear camber on your motor can be adjusted so you only need the front parts
[IMG]local://upfiles/12092/24A7E6548CFC48A28B98BFB478860C88.jpg[/IMG]
Old Feb 23, 2006 | 05:45 PM
lamchop's Avatar
Sorry to hijack but I am trying not to be in the same position as you are in now.What would be the best offset? My car is a 2000 A4, I am looking to lowering it, What backspacing do I need for 18*8 wheels?
Old Feb 23, 2006 | 06:17 PM
BFlan2001's Avatar
for 18x8 i think a 45 offset is about what you want
prodrive, i do still have the steering wheel but it doesn't include the airbag, just the steering wheel itself
Old Feb 23, 2006 | 08:07 PM
prodrive's Avatar
ORIGINAL: avant80@2.6
Thats cool man , is it ETKA ? I need that s/w urgently thanx but the fronts will cost 600 $ [:@] at purems.com.
I am thinking now rolling the fenders or upgrading the sways.
Old Feb 23, 2006 | 08:14 PM
prodrive's Avatar
ORIGINAL: bentframe
I should search for an airbag than ... it might be stupid question but can I use 4 spoke air bag ?
Old Mar 3, 2006 | 02:48 PM
BFlan2001's Avatar
nope, you'll need an airbag from a 3-spoke wheel...the airbag is actually the whole center piece, including the faceplate and audi rings in the center.
Old Mar 3, 2006 | 02:54 PM
Talis's Avatar
hey man you can just press the print screen button instead of taking pictures of ur monitor, print screen is right next to f12 and scroll lock
