Damn Sqeaking Noise
Old Jul 2, 2007 | 10:17 AM
lbcquattro's Avatar
Default Damn Sqeaking Noise
Ok, when first start the car in the morning I get this sqeaking noise that sound similar to a belt sqeaking. It fades away within a minute to 2 minutesupon startingthe car. I put some belt dressing on the serp belt, and it didnt fix it. I notice now whenever the fan turns on, I get the sqeak too. It will then cease when the fan turns off. What do you guys think?
Old Jul 2, 2007 | 10:32 AM
akielb's Avatar
Default RE: Damn Sqeaking Noise
if you turn off your A/C does the noise go away? If you turn off the whole air system, does that change anything?
Old Jul 2, 2007 | 02:47 PM
lbcquattro's Avatar
a/c isnt ever on. It does it without the air system being on at all.
and while I am at it, my brakes have a clicking noise in them, only when I get under 20 miles a hour coming to a stop, there is a clicking sound, and I feel it in the pedal. I had the rotors turned, and the pads check out, and it still does it. Got any advice on that?
Thanks
Old Jul 2, 2007 | 03:03 PM
auditech79's Avatar
ORIGINAL: lbcquattro
Thanks
Try taking off the entire serpintine belt just to make sure that the squeak is coming from that area.
As for the brakes it sounds like an antirattlingclip is either loose or broken.Do NOT turnaudi factory rotors, they are made of a very soft material and should never be turned on a laythe. This will make the disc heat upfaster andwear thebrake pads a 2X the rate.
DanaB6
Aug 14, 2012 09:42 AM
Bltprf502
Dec 5, 2008 10:22 PM
SAudi
May 1, 2007 02:34 PM
99a4audi
May 17, 2006 11:14 PM
