dash lights
Old May 31, 2005 | 12:06 PM
AMeicher's Avatar
Default dash lights
How hard is it to replace the top mounted speedo light in an 98 a4? Just wondering how much time and if anyone knows a couple tricks if it's a pain to do. It's burned out between the 60-110 mark.
Old May 31, 2005 | 12:09 PM
Jestnomen's Avatar
6th Gear
Default RE: dash lights
It's pretty easy. The trim below the cluster just pulls off. Underneath is 2 philips screws - remove them. The instrument cluster will wiggle out. There should be 3 or 4 plugs on the backside. reach behind and pull them off. From there you can access the lighbulbs.
Old May 31, 2005 | 12:19 PM
AMeicher's Avatar
I was going trough the Audiworld website and found it after I posted the topic, I havnt looked at how to do it while sitting in my car yet. it looks stupid simple from the pictures. Thanks Jest
Old May 31, 2005 | 12:54 PM
Jestnomen's Avatar
6th Gear
yep shouln't be a problem. Make sure you place a towel down on top of your steering wheel. The dash tends to scratch the trim when it comes out.
nize
Jun 21, 2013 01:16 PM
SAudi
Aug 20, 2009 11:36 PM
sam.hollis
Feb 14, 2008 11:36 PM
blockp
Jan 30, 2008 01:04 AM
alan93
Jul 6, 2007 09:49 PM
