dead clutch
Old Nov 8, 2005 | 08:51 PM
soundmann18's Avatar
Default dead clutch
The clutch in my 96 A4 has died. Except that, instead of being stuck in gear, its stuck out of gear, i.e. even if I let the clutch out all the way the car doesn't stall. So is this how clutches work on A4's? or is there something else wrong?
Old Nov 8, 2005 | 08:52 PM
clconversion's Avatar
Default RE: dead clutch
sounds like a clutch issue but until you get into it you won't know
Old Nov 9, 2005 | 01:58 AM
CrazyBignate's Avatar
ai ai ai, sounds like trouuuuble
Old Nov 9, 2005 | 02:34 AM
Dj Spiel's Avatar
I am assuming its a V6 2.8L QUattro
**The clutch goes out usally after 100,000 Miles
If you cannot put the car in a "gear" no matter what you do... & you smell something funny from under hood. It's your Clutch.
It's like theres a Brick in front of your shifter stopping you from getting into a gear right?
Sachs OEM Clutch 200 on EBAY
FLywheel for about 80 bucks at junkyard
Labor about 500
ORIGINAL: soundmann18
Old Nov 9, 2005 | 06:22 AM
Not a Quatro, but yeah. The clutch goes in and out fine, it just doesn't go into gear, but the rest of the symptons are true. And the shifter is working fine as well. The car's over at the AAMCO now, I'll be calling them up in the morning.
Old Nov 9, 2005 | 06:26 AM
Dj Spiel's Avatar
Yeah its ur clutch dude.
Good luck with fix let us know outcome.might wanna consider getting aftermarket clutch will last longer
thorjov
Nov 4, 2015 09:19 PM
tom.beckman
Sep 2, 2013 10:19 AM
coast2coastdrvr
Apr 13, 2010 12:47 PM
wdiaz300
May 14, 2008 08:10 PM
AvantGarde02
Oct 22, 2006 12:08 AM
