Debadging 1999 A4
Old Apr 9, 2005 | 08:26 PM
azarlengo781's Avatar
Default Debadging 1999 A4
I just wanted to ask how the badges are on there? Glued or with screws or anything? Thanks... im just trying to toake of the A4 and 1.8T
Old Apr 9, 2005 | 11:08 PM
PandaXpress's Avatar
Default RE: Debadging 1999 A4
they glued
Old Apr 10, 2005 | 12:17 AM
BFlan2001's Avatar
a heat gun and fishing line. floss is worthless...get some strong fishing line and it'll take you 3 minutes for each side....to remove the glue residue use GOO GONE (it's citrus-based and won't damage your paint)
DO NOT USE GOOF OFF!!!! it will damage your paint bad...
Old Apr 10, 2005 | 07:14 PM
Covz's Avatar
CAn i use WD-40... also is the audi logo just glued on also???
Old Apr 10, 2005 | 07:15 PM
audiboy1618's Avatar
I used lighter fluid....
Old Apr 10, 2005 | 08:59 PM
BFlan2001's Avatar
wd-40 and lighter fluid will probably both dull your clear coat...audiboy, what color car do you have?
if you have a black car i wouldn't use anything but goo gone....
Old Apr 11, 2005 | 10:35 PM
jlaudio184's Avatar
lighter fluid worked great for mine and i have a gunmetal metalic paint, no damage done. I recomend giving the tailgate a light buff right after to reduce the fade from the sun not hitting the paint under the badges.
Old Apr 12, 2005 | 01:39 AM
BFlan2001's Avatar
i would think that lighter fluid wouldn't be good for the paint. but apparently i'm wrong......
Old Apr 12, 2005 | 03:48 PM
swift_A4's Avatar
after i used goo gone i used this stuff by meguires (can't remember the spelling) cleat coat. then i waxed the area. can't see a thing.
Old Apr 12, 2005 | 05:51 PM
clconversion's Avatar
I used a belt sander worked awsome
