Decided on BT
Old Nov 30, 2007 | 03:41 AM
  #31
AudiCross's Avatar
Default RE: Decided on BT
wow!! i like those numbers!! umm... u said i hasdve stock WB, whats that?
Old Nov 30, 2007 | 11:47 AM
  #32
sean1.8t's Avatar
sorry, Wideband
Old Nov 30, 2007 | 12:12 PM
  #33
AudiCross's Avatar
widebandddd...does that have to do with the change in valve timing with the VVT and where it happens?
Old Nov 30, 2007 | 12:30 PM
  #34
sean1.8t's Avatar
not that im aware of.. but your car, and all B6's have a wideband o2 stock. the ECU is programmed with the target AFR(around 11.4:1 at WOT) and will change fuel trims accordingly to maintain that.. therefore, a MAF is not necissary for most setups on WB equipped cars. i don't run one on my car and it runs great.. but for a kit like the APR stg3+, you'll run one
btw, VVT just induces overlap to suck spent exhaust gas back into the cylinder to help with emissions at cold start. It is merely a selenoid that when activated preses on the cam to cam timing chain to rotate the cams and change timing. it is just for cold starts. nothing special like VTAK[8D]
Old Nov 30, 2007 | 12:41 PM
  #35
AudiCross's Avatar
really? i thought it was just audi's version of v-tec. So it just induces valve overlap?
Old Nov 30, 2007 | 12:43 PM
  #36
auditech79's Avatar
Im beginning to like the APR Stage III kit more and more everytime i hear about peoples good experience with them.
Oh and audicross, it says in your sig that you got a 2bennett clutch as well, can that clutch handle the power your looking for?
Old Nov 30, 2007 | 12:46 PM
  #37
AudiCross's Avatar
I believe so. Not 100% sure tho. It is 740 kg/in pressure, which is nearly double stock. i dont know what the friction material is though. I am conna contact them later today and see what they say. If it isn't, i will just have to suffer and try not to do any hard launches, because after the BT setup, cash defanitly wont be as liquid. lol
Old Nov 30, 2007 | 01:50 PM
  #38
cincyTT's Avatar
I'm make believe
ORIGINAL: sean1.8t
Not anymore. Mike Z and Unitronic are apparently getting the VVT to work with their sw for added benifiets.
Old Nov 30, 2007 | 02:05 PM
  #39
AudiCross's Avatar
wait, come again? so we can get our car's VVT to work for power gains?
Old Nov 30, 2007 | 02:16 PM
  #40
sean1.8t's Avatar
ORIGINAL: cincyTT
ORIGINAL: sean1.8t
ok, got a vortex link?
