did this diy and wtf!
http://www.audiworld.com/tech/ext38.shtml
did this diy today and im not getting no reverse lights when i pop her in reverse. im getting white turn signals which should obviously be the reverse. can anyone tell me which wires to switch back before i mess up the harness. any help appreciated, thanks
RE: did this diy and wtf!
that seems pretty self explanitory i dont know how it could be messed up haha...but anyway, are the wires you switched the same colors as the ones in the pictures? because im going to guess that its more importent to follow the wire colors than it is to just switch '1 & 3'
yes i followed the directions. before i switched them the lights wouldnt even turn on, no signal, no reverse, nothing. so if iswitch them back im guessing im not going to get any lights again.yeah i checked the numbers and the colors before i switched them. it seems pretty impossible tomess upso idk. please help guys.i have a 97.
well not sure if this will help you or not be here is the wireing diagrams for MY97 and MY2000
97 - http://i142.photobucket.com/albums/r...g?t=1177782078
2000 - http://i142.photobucket.com/albums/r85/akielb/00-Tails.jpg?t=1177781871
dang i dont know man when i did that DIY on my 96 everything worked out perfect. Just make sure you switch those two wires around or else that would cause white turn signals! You dont plug the wires back into the same spot you took them out of, just makin sure you know that. Good luck and the only thing i could think of that your doing wrong is not switching spots with those two wires.
