Did my turbo just die?
Subscribe
Jul 18, 2006 | 02:38 PM
RE: Did my turbo just die?
Quote:
ORIGINAL: RLB6
Quote:
ORIGINAL: smokeU
what is the best way to check that hose? get it on stands and check from the bottom? or can it be checked from under the hood?
I would say remove the front bumper to get a good view of the piping from turbo to IC to intake. I'm not sure of an other way..that's easier than this atleast.
All you have to do is take the belly pan off and its right under there in front. Taking the bumper off only exposes the radiator/ac condenser/front of IC. You can see all of the turbo/IC piping by simply looking under the car with the belly pan off.
Reply
Jul 18, 2006 | 03:27 PM
Bingo.
Reply
Jul 18, 2006 | 04:02 PM
thanks onepointeightT that makes more sense. I was wondering how I would see through the radiator... could always use the x-ray vision... hmmmm....
Reply
Jul 18, 2006 | 05:46 PM
Def let us know what this turns out to be..
Reply
Jul 18, 2006 | 05:52 PM
is that rod at the rear of the turbo still connected, something to do with the accelerator peddle hum it has happened you know just a thought
Reply
Jul 18, 2006 | 11:16 PM
Well I called the Audi dealer after leaving it with them for over six hours and not hearing back. Turns out the check engine light came on right as I was pulling up, and the code said three different cylinders were misfiring. The guy cleared the error, and drove it around all day and he can't get another check engine light to come on, although he can feel the engine misfiring. So they have to keep it overnight to figure out what the hell is going on. I don't know why I thought it was the turbo yesterday, but as soon as I started driving it today I figured it was a spark plug. Since the code said it was three different cylinders having a problem, it doesn't sound like it’s related to a spark plug, though. Anyone have any thoughts on what it might be?
Reply
Jul 19, 2006 | 02:02 AM
hmmm my 2 cents goes to a maf sensor......I had the same crap go with my car....when it would idle it would jump rpms and loose power and it staled a couple times....
Reply
Jul 19, 2006 | 02:05 AM
  #18
yeah probably not entire turbo failure, i would pull engine codes if you have a CEL if not, trace your intercooler and boost lines
Reply
Jul 19, 2006 | 12:41 PM
  #19
Im guessing MAF too. If its going bad, it can cause you to run rich which will cause missfires and bucking. If it turns out to be the maf, make sure you replace your spark plugs too cuz theyve probably gone through some hell in the process of the dying maf. Ive read a few times where peoples maf's have gone bad, and when they get it fixed, their car still doesnt feel like it used to, and thats probably because their plugs got so carbonized in the process of running rich from the bad maf that its not getting the best spark anymore, which can lead to fuel not getting fully combusted, which leads to bad mpg, and early 02 sensor and cat failure blah blah blah..... But then again, it may not even be your maf?!?!?
Reply
Jul 29, 2006 | 03:37 AM
  #20
I got my car back after the dealer having it for four days saying they couldn't replicate the problem. A week later, guess what it's doing? This time the battery light came on while it was bucking and then it completely stalled. What the hell should I tell these clowns to do, as its apparent they won't do anything on their own?
Edit-The next day I called the dealer and a small audi/vw repair shop and they both said they need the check engine light on, so to just drive it around more until the computer spits out an error. When I tried driving my car around, it ran perfectly! I drove it about 12 miles without a problem. I'm afraid to take it on the freeway to work (30 miles one way) as I don't want to be stranded somewhere, yet if I don't drive it around no one can help me. [:@]
Reply
