difference between 1.8T engines
Old Nov 18, 2007 | 10:30 AM
MaXo's Avatar
Default difference between 1.8T engines
Hallo,
I saw in Dahlback site about chip tuning. And there I read this:
"The above specified torque 236lb-ft is valid for 97 cars. On 95-96 cars the torque reaches 212 lb-ft and from 98 and onwards the torque reaches 260 lb-ft."
Can you tell me what is the difference between this engines. What are their designations?
I want to buy A4 B5 1.8T 150hp and I wonder which engine is better
Old Nov 18, 2007 | 10:35 AM
turbo kraut's Avatar
Tech Guru
Default RE: difference between 1.8T engines
are you sure those are audi motors they are talking about?
cause the audi 1.8 motors from what i recall....... all 1.8's prior to the awm motor were 150bhp, the awm moved up to a wapping 170bhp
but the vw has a 180bhp and i think 190bhp motor
Old Nov 18, 2007 | 10:41 AM
MaXo's Avatar
everything that I quoted is about Audi 1.8T 150hp engines.You can see it there anout Audi A4 1.8T stage 1 http://www.dahlbackracing.se/english/main.asp
Old Nov 18, 2007 | 12:06 PM
tdn's Avatar
tdn
That site's always been confusing.. I'm sure do to the translation. I'm sure your Dalhback dealer can give you better answers.
Old Nov 18, 2007 | 02:18 PM
chaos92287's Avatar
sounds like they got their years mixed up. anything pre-00(aeb engine) should be the same, the 00 and 01 should have different results due to the k03s
Old Nov 18, 2007 | 02:53 PM
A4speed's Avatar
ORIGINAL: chaos92287
not 00, its 01+
99-00 have 150hp
2001+ 170hp
Old Nov 18, 2007 | 02:56 PM
BaconBait's Avatar
That's not entirely true.
pre 00 does have the AEB with the larger intake ports.
2000 has the ATW, whis basically an AEB with small intake ports, 19mm wrist pin (AEB has a 20mm), and it's the first year with throttle by wire. It still has 150hp.
01+ has the AWM. They changed a lot on the bottom end of the motor for the accessories, the head has variable valve timing, and one or two other things I can't remember off the top of my head that up the hp.
Old Nov 18, 2007 | 03:06 PM
chaos92287's Avatar
exactly, pre-00 should all have the same results cause they all have an aeb engine and regular old k03. i thought the k03s was introduced in 2000 for some reason. guess i was mistaken. but in 01 they added the k03s, changed the programming by .2 Bar, and lowered the compression slightly. VVT is for emission purposes only, not adding power
Old Nov 18, 2007 | 03:23 PM
bob12312357's Avatar
ORIGINAL: turbo kraut
I purchased today an 01 after test drivin several 98,99's,00. There is a huge diffrence in highway passing power available and 3rd gear pulls much harder with the 170hp on tap. This car is so damn smooth i didn't realize i was doin 85 in a 45 on the 120 mile trip home till my boy who was following calls and is like slow the *** down.lol Just seems a bit smoother and more refined then the 99's 150hp engine.
Old Nov 18, 2007 | 06:31 PM
MaXo's Avatar
http://tuning.3x.ro/audi.html
AEB-stock 150hp 210nm... with chip 187hp 280nm
ANB, AGU, AWT, AUM, APU, AVJ- stock150hp 220nm ...with chip 195hp 287nm
AWT, AQA, ARZ- stock 150hp 215nm... with chip 210hp 300nm
http://www.autoshoppingcenter.com/Vo...ginescode.html
