Difference Between BLOWN CLUTCH and DEF. CLUTCH CYL
Old Apr 9, 2010 | 09:37 PM
mack1time's Avatar
Default Difference Between BLOWN CLUTCH and DEF. CLUTCH CYL
Today I tried to shift into second at hight revs. Something cluncked and my clutch got really loose. It was still drivable and the shifts were rough but I made it home. I tried to drive around the block and eventually got stuck in first.
Now my clutch petal feels really loose. I can hold it down all the way to start the vehicle but I cannot lock into any gear via the manual shifter and petal. I can get it to pop into 3rd with the correct revs and eventually stall and I do hear some spinning. Also when it is not running I can play through and lock into all the gears.
How do I know if it is a problem with the clutch petal, clutch master or slave cylinder, or the entire clutch needs to be replaced. I am scared of taking it to a mechanic and have them diagnose in their favor.
I checked the brake fluid and it is fine. No leaks.
ANY HELP WOULD BE GREATLY APPRECIATED
Old Apr 9, 2010 | 11:02 PM
turbo kraut's Avatar
Tech Guru
see your other thread
mdudu
Sep 15, 2008 06:07 PM
Mixmastermike
Jan 1, 2008 12:43 AM
FirstAudi06
Sep 14, 2007 03:12 PM
juice88
Dec 7, 2005 01:01 AM
99AudiA4q
Jan 8, 2005 09:43 PM
