difference between K&N - lltek air intake
Old Jan 2, 2006 | 10:18 PM
specialK4's Avatar
Default difference between K&N - lltek air intake
what is the difference between the K&N intake priced at 55$ and the lltek air intake priced at 250$
both are air intakes by brands known for good quality i just dont understand why one is priced 200$ more???
Old Jan 2, 2006 | 10:20 PM
tip5's Avatar
Default RE: difference between K&N - lltek air intake
its kinda like walmart and nordstroms. Both might have the same thing but not really. Id go with K&N air intakes dont really do much for audis especially for a 200+ price tag.
Old Jan 2, 2006 | 10:22 PM
Kellya4's Avatar
The biggest difference is throttle reponse and sound. The lltek intake will give you much better response than a K&N drop in filter.
Old Jan 3, 2006 | 04:08 AM
specialK4's Avatar
is it really worth the extra 200$?? i mean u dont even get alot of HP from a CAI
tip5 - uh i think u need to re read the post also K&N's are known to have good parts as well as lltek , thatsd where im at a loss
Old Jan 3, 2006 | 02:05 PM
Kellya4's Avatar
If you have a 2.8, the lltek CAI helps to eliminate the "flat spot", between 2000-4000 rpm where the motor is kinda slow, that's why i got it. With the cat back exhaust, it really makes a differance, and throttle reponse is improved as well.
Old Jan 3, 2006 | 02:27 PM
TheJazz7's Avatar
Yeah, I've got a 2.8 and that deadspot can suck...I just bought a used LLtek intake from someone on the forums for about half the cost of a new one. Hasn't showed up yet (fingers crossed), but can let you know if it was worth the investment once I get it installed. If nothing else, I should at least get a nicer sounding growl under acceleration.
Hell, I spent more $$$ than that on booze this past weekend without even thinking about it :-)
Old Jan 5, 2006 | 04:13 PM
specialK4's Avatar
thx yea booze is expensive lol...let me know how that CAI turned out
Old Jan 5, 2006 | 04:29 PM
FezA4's Avatar
The K&N is a drop in filter. It only replaces the stock filter box. The lltek kit replaces the entire intake housing. You have to take out the intake tubes that run from the grille into the turbo housing, Its a filter comparing to a kit. Two diff fields.
Old Jan 5, 2006 | 04:30 PM
clconversion's Avatar
Both are **** and will give you no gains at all don't waist your money
Old Jan 5, 2006 | 11:32 PM
TheJazz7's Avatar
Awww, don't go player-hating on my new intake :-)
Our airboxes are pretty unrestricted, thats true...so I'm definitely going in with low expectations. Lltek claims 10+ HP gain, it'll probably be closer to 5. Plus smoother throttle response, some growl under acceleration...gotta do your own cost/benefit analysis my friend. And you're definitley paying a premium for the Lltek brand.
If I end up not liking mine, I can hook you up for a reasonable price
skunkoncrunk
Jan 3, 2008 05:10 AM
nverstoppin
Mar 27, 2007 01:27 PM
rowingdude
Dec 19, 2005 10:36 PM
rowingdude
Dec 19, 2005 06:02 PM
rowingdude
Dec 19, 2005 05:47 PM
