differtials?
A4's use one mechanical/helical center differential made by Torsen. the front and rear diff's are open. audi uses edl to reduce wheel spin which relies on the abs system. e-brake is a bad idea considering that the front and rear split is 50/50 and it doesn't change to much from that. You will only cause pain and suffering.
