differtials?
Old May 5, 2005 | 03:55 AM
luvin_the_rings's Avatar
Default differtials?
what equipment does the quattro system use?
ex. differentials (where?) (center, front, rear) stuff like that
and will e-brake 180's mess up my system?
Old May 5, 2005 | 04:32 AM
brrman's Avatar
Default RE: differtials?
ebraking will have a negative affect on your drivetrain. The only time to do it is in the snow.
Old May 5, 2005 | 12:45 PM
acvega's Avatar
A4's use one mechanical/helical center differential made by Torsen. the front and rear diff's are open. audi uses edl to reduce wheel spin which relies on the abs system. e-brake is a bad idea considering that the front and rear split is 50/50 and it doesn't change to much from that. You will only cause pain and suffering.
Old May 5, 2005 | 01:01 PM
TGPorsche96's Avatar
I've been doing them in the rain ...is that alright for the differential with using the e-brake....?
Old May 5, 2005 | 02:22 PM
brrman's Avatar
ORIGINAL: TGPorsche96
No.. not really. Even worse for your wheel bearings.
Old May 5, 2005 | 05:52 PM
any way to replace the front and back open diffs with helical, or viscous? how about a 2 or 1.5 way?
