diode mode
ORIGINAL: Bondga
dont need to add fuel thsts what the maf is for
There is a little more to it then that. If you crank up the boost, you NEED to add fuel, as you have exceeded the stock ECU adaptations.
ORIGINAL: cincyTT
You still within the ecu's capabilities. I run 20psi and never had to touch my fuel trims. Its when you mess with the MAF and change its reading you need to add more fuel
Since he is getting the flashing cel, my option would be to add some fuel.
I still have stock fueling running the stock 3bar fpr. I agree that adjusting it is better for optimum gains, but isnt neccisary to run safely. The flashing lights should be due to misfires from his plugs not being gapped correctly. Until he gaps them to .028, i dont think he has to worry about fuel just yet.
ORIGINAL: cincyTT
Guys, detonation is one of the fastest ways to blow up a motor.
The flashing cel is from the missifres, which is caused by...... THATS RIGHT, him blowing out the spark in his incorrectlygapped plugs. For all we know, he could of not gapped them when they were installed and at .035 or bigger. Said it before and ill say it again.... Fuel is in check and fine to run at 18psi without any changes and his problem is the gap on his plugs. If you wish, you can run logs and adjust it as needed.
hi, little update on what was done to my car, after i regaped my sparks my car runs fine, so i installed mbc again no problem this time, as on today i’m running 12 psi few times seen spikes up to 15psi, i will try to expirement with higher psi (<18) whenever i have time.
thank you guys so much for all your help!!!!....
Now k04, giac, 22psi, no MAF, ph33r!
