Diverter valve
Old Jun 8, 2006 | 02:09 AM
patmine23's Avatar
Default Diverter valve
I was wondering how I determine which diverter valve that I need for my 2003 A4 1.8T. And also are there much gains when changing this valve? I was looking at the forge brand, the correct one to buy is what I'm after. Thanks for youre help
Old Jun 8, 2006 | 02:11 AM
miked's Avatar
Default RE: Diverter valve
No gains, it simply can hold higher levels of boost. No need to buy one unless you are going to chip your car. And if thats all you are going to do, all you need to get is the 710N DV from the Audi TT. $35.
Old Jun 8, 2006 | 02:38 AM
patmine23's Avatar
I will be doing the APR ECU upgrade, probably in the next several months. Which one will do the job best for this application?
Old Jun 8, 2006 | 02:39 AM
miked's Avatar
The 710N is all you need.
Old Jun 8, 2006 | 03:21 AM
kraylon's Avatar
i got the forge 007 dv and it works great and you are able to rebuild it if you need to and the other thing that i like is someday when you get one of the big kid turbo kits you just change the spring to hold different boost levels
Old Jun 8, 2006 | 06:59 AM
Dj Spiel's Avatar
get the 710N
You can here turbo more
30 min install by urself *i just did mine today*
ORIGINAL: patmine23
Old Jun 8, 2006 | 10:55 AM
north5995's Avatar
I have the forge. With the forge you have the ability to change your boost levels. They have springs inside which you can swap out.
Connor Schleicher
Nov 8, 2011 07:13 PM
07titanium
B7 Models
Oct 25, 2011 08:11 PM
justinclink1
Aug 30, 2010 11:40 PM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
