Diverter valve related to pinging...
Old Sep 13, 2006 | 07:55 PM
SilverPullit's Avatar
Default Diverter valve related to pinging...
question, would installing my Forge 007n diverter valve backwards cause my motor to ping at higher rpm's? could the spring be too strong? just curious because my motor pings at about 4K in all the gears (checking every possible cause even though GIAC told me to go get the latest flash). thanks.
Old Sep 13, 2006 | 07:57 PM
techbod's Avatar
Default RE: Diverter valve related to pinging...
yes it would
Old Sep 13, 2006 | 08:33 PM
so if i put the valve on the correct way i should not experience the pinging..at all?
Old Sep 13, 2006 | 08:36 PM
techbod's Avatar
you can only try and let see the results, Ive heard of this mod but not convinced it does anything good to the engine
Old Sep 13, 2006 | 08:40 PM
techbod's Avatar
I mean lets be honest if you were on a ventilating machine to save your life ( air in - air out ) or partial air in/out which would you go for
Old Sep 13, 2006 | 08:53 PM
ok thanks.. i will try this tonight.
Old Sep 14, 2006 | 12:44 PM
patty AT forge's Avatar
If this were the case it would mean that the car, or at least the reflash, was designed with a leak from the valve expected in the system.
Pinging is caused when the relationship between octane, RPM, cylinder pressure, A/F and spark advance is incorrect.
Old Sep 14, 2006 | 01:11 PM
smokeU's Avatar
why are people putting their DV's in backwards? [sm=icon_stickpoke.gif]
Old Sep 14, 2006 | 01:23 PM
chuckievi's Avatar
I blame the ricers.... they have some disease infecting the mind.....
Old Sep 14, 2006 | 01:25 PM
smokeU's Avatar
lol... [:@] RICERS [:@] CORN [:@] SCHNITZEL [:@]
