DIY dual SMIC's
Old Apr 24, 2007 | 01:34 PM
Matt_Iliketurbopull's Avatar
Default DIY dual SMIC's
Hi tasteful Audi fans,
has anyone used twinSMIC's on an Audi A4 B51.8T quattro? for example using standard intercoolers and piping them together (one on each side of the car).
I'm not sure if can fit a second SMIC, but it might be a good idea, use up old standard intercoolers lying around,increase heatsink/airflow capacity on the cheap...
Old Apr 24, 2007 | 01:36 PM
new2me's Avatar
Default RE: DIY dual SMIC's
I think its cheaper and easier to just run a fmic.
Old Apr 24, 2007 | 01:41 PM
Flip's Avatar
Fmic's look better too imo.
Old Apr 24, 2007 | 01:43 PM
kraylon's Avatar
and fmics probaly work better since there would be no filter to filter out the air going in to the motor
Old Apr 24, 2007 | 01:44 PM
kraylon's Avatar
on the dual side mounts
Old Apr 24, 2007 | 03:05 PM
cincyTT's Avatar
I'm make believe
Kraylon, it would go from one ic to the other. No need for a filter.
A correctly sized front mount or upgraded sidemount (boostfactory has one) will be much better at lowering temps and will flow much greater than a dual set up.
Old Apr 24, 2007 | 03:14 PM
2k S4's Avatar
I got a set of stock S4 SMIC's, if you want to play around.[:@]
Old Apr 24, 2007 | 03:39 PM
NuYorka103185's Avatar
What about 2 smic WITH a fmic. I call ita tfic setup. Tri-fecta intercooler. Oh snap, he's gone crazy!!
Old Apr 25, 2007 | 01:09 AM
quattrosedan's Avatar
you should throw a top mount in there too from a rex.....then it could be a quad setup....I bet there wouldn't be too much of a pressure drop there.......
Old Apr 25, 2007 | 07:09 AM
yes thanks for replies, I think your right go with FMIC, I was just trying to be a cheap skate especially like if only going with a chip upgrade, but even then those Godspeed intercoolers look pretty affordable.
Plus I plan to go with a GT turbo and PES software so why not spend a bit more on IC.
I was curious though if ever been done.. I wonder if those S4 IC's would fit? they should be bigger than the A4 IC I guess.
