DIY : need help - Windwasher reservoir replacement
Old Feb 24, 2006 | 07:58 PM
j_ripper19's Avatar
Default DIY : need help - Windwasher reservoir replacement
Hi and thanks in advance for reading this,
Recently i've stumbled across a leak in the water windwasher system for the windshield. The sign for low water level is always on and I think it's the reservoir that has a leak, so I need to replace it.
Can anyone help me with some pointers? I want to know if it's a PITA or really expensive on parts? Also I think it's the reservoir but I can be wrong, if you have any idea why I should think otherwise please let me know.
BTW, it's not electric either. When I add the water I can confirm that it leaks under the car.
Thanks in advance for any suggestions!
Old Feb 24, 2006 | 08:37 PM
Kellya4's Avatar
Default RE: DIY : need help - Windwasher reservoir replacement
This would be your washerfluid pump, they split all the time. Just replace the washer pump and the leak will more than likely go away. This has happened on mine once and a friends as well.
Old Feb 24, 2006 | 09:22 PM
BadLuckAudi's Avatar
MY pump was leaking all i had to do was put a little silicon sealer around it and twist it back in works great now
Old Feb 25, 2006 | 01:24 PM
Jestnomen's Avatar
6th Gear
Use this tutorial:
http://www.audiworld.com/tech/misc28.shtml
Typically it is the pump housing that cracks. You'll have to do some investigation though.
Old Feb 25, 2006 | 04:20 PM
j_ripper19's Avatar
Thanks for the help, guys and for the tutorial, Jest. Doesn't seem to be a great PITA, so I'll tackle it next weekend.
Old Feb 25, 2006 | 04:44 PM
onepoint8tee's Avatar
Wow i need to do that, i just never could find a DIY and got lazy.. I have never seen the"OK" on the dash before... Just the erupting volcano!.. Im gunna do this next weekend too.
Old Feb 25, 2006 | 05:01 PM
Jestnomen's Avatar
6th Gear
Yeah it's fairly straight foward. I had a leaking pump on my B5 that I had to replace. Probably took me 2 hours total time.
Shly986
Oct 19, 2014 06:42 PM
bbennett001
Oct 19, 2013 02:03 PM
stockgp
Jul 27, 2011 09:57 PM
DaveFan782
Jan 14, 2007 03:35 AM
mcicoria
Aug 23, 2006 12:09 PM
