do these have the correct offset??
Old May 11, 2005 | 02:44 AM
mlo517's Avatar
Default do these have the correct offset??
http://www.eurotrenzinc.com/w_sevas.shtml
Do the Sevas S-star fit a 1999 2.8 a4 quattro?? any help is appreciated
Old May 11, 2005 | 04:02 AM
mlo517's Avatar
Default RE: do these have the correct offset??
anyone know?
Old May 11, 2005 | 04:30 AM
PandaXpress's Avatar
they do have our bolt pattern of 5x112 but they dont say the offset though but they will fit your car i seen them on audi A4s but B6s though
Old May 11, 2005 | 02:13 PM
mlo517's Avatar
if they fit the b6 does that mean they should fit the b5s as well?
Old May 11, 2005 | 02:46 PM
Yuikio's Avatar
Not necessarily. Just send them an email, ask them what offsets they offer, or ask them if they have B5 customers with the wheel you want. If they can only tell you about the offset, tell that to us and then we can help you out.
Old May 12, 2005 | 09:51 PM
mlo517's Avatar
I emailed but no response yet, although i found this..........
http://www.bnzsport.com/forums/index...ic=13480&st=30
In the Benz forum Eurotrenz says they have 35-40 offsets, does that mean they will fit? And I want them to fit nicely, what exact offset would you guys recommend?? I dont want them sticking out too much but I also dont want them going in at all..
Old May 12, 2005 | 10:45 PM
brrman's Avatar
yes a 35-40 offset is ideal for an A4 - 35 is nearly flush with the fender
this is 35 offset
Old May 12, 2005 | 10:50 PM
mlo517's Avatar
so does that mean that 45 will stick out a little??
Old May 13, 2005 | 12:30 PM
Dr Pooface's Avatar
ORIGINAL: mlo517
No, they will be tucked in a bit. Wheel width plays a roll here as well.
Keep in mind that while reducing offset looks cool, and gives the car a more stable feel by increasing the stance, it has several negative drawbacks. Steering will become a little harder, which you may or may not notice due to the power steering system. Your turning radius will be increased. Lastly, because of the added leverage imposed on the suspension the springs will, in effect, feel softer. All of these items can be attributed to the added distance the wheels are placed from the suspension with a reduced offset.
http://www.tirerack.com/wheels/tech/offset.jsp
capn
Nov 14, 2012 05:34 PM
ChadS89
Jul 19, 2008 10:33 AM
Philthykins
Mar 17, 2007 04:19 PM
cnelson81
Jan 27, 2006 07:16 PM
