how correct is the...
Old Jan 25, 2006 | 05:15 PM
cnelson81's Avatar
Default how correct is the...
display in the cluster, it shows that i get about 12 the city, and 17 or so hwy.. does that sound correct?
Old Jan 25, 2006 | 07:24 PM
Audijunky's Avatar
Default RE: how correct is the...
NO it sounds low probably should be around 18 city 23 hwy
Old Jan 26, 2006 | 05:00 AM
cnelson81's Avatar
thats waht i was thinking, what is a good way to check to see waht it may be? any input would be phenomenal
Old Jan 26, 2006 | 03:30 PM
slee22's Avatar
Divide the number of miles your car ran on a full tank by the number of gallons of gas your car holds.
Old Jan 26, 2006 | 08:04 PM
cnelson81's Avatar
yes I know that is the way to correctly find the numbers, but i was wondering why the dash one would be so far incorrect?
Old Jan 27, 2006 | 05:52 PM
slee22's Avatar
Oh sorry. Not sure why it's off, but if you watch it while you drive it changes with every input you make to the gas pedal and it averages that instead of taking the actual miles divided by tank capacity...could be the reason.
Old Jan 27, 2006 | 07:16 PM
hzhao's Avatar
If I understood correctly, the on-board computer is using the past two seconds data, then average over the time from your last reset. So, if you leave the way it is and after few full tanks re-fill, the number should be fairly close to normal. If you reset it too often, the computer just don't have enough history to calculate the average.
ziobello
B7 Models
10
Mar 8, 2013 04:40 PM
K1196A
Jan 7, 2009 11:02 PM
Philthykins
Mar 17, 2007 04:19 PM
Philthykins
Jan 23, 2007 05:41 PM
mlo517
May 13, 2005 12:30 PM
