downpipe vs. testpipe
Old Jan 27, 2007 | 07:41 PM
99A4QT's Avatar
Default downpipe vs. testpipe
hey guys right now i have a greddy exhaust system, but still have the stock downpipe. Im trying to figure out what the diff. between a downpipe and a test pipe if there is any. I really need the downpipe so i can really get the full potential out of my exhaust and by getting rid of the stock downpipe i think that is the best bet. So i guess my question is what should i do, or get
Old Jan 27, 2007 | 07:53 PM
onepoint8tee's Avatar
Default RE: downpipe vs. testpipe
test pipe replaces cat. from front to backthe exhaust manifold -Turbo-Cat - DP - Resonator- Muffler
A lot of exhaust kits come with a dp and if one doesnt there arebiggeraftermarket ones to get.. So the test pipe and the down pipe are two different things.
Old Jan 27, 2007 | 08:59 PM
AudiTurbo's Avatar
atp makes a get testpipe/cat delete..... http://www.ecodetuning.com/shop/cart...tail&p=671
Old Jan 28, 2007 | 06:25 PM
tcuphigam's Avatar
I am really thinking about buying that testpipe for my b6 T quattro. This would be my first mod, is there anywhere I can find instructions for removing the cat, sensors, etc and installing the TP, sensors, etc?????
Old Jan 28, 2007 | 07:03 PM
widgget's Avatar
Intresting for a first mod. I would do some research before you start just putting random parts in your car man.
Old Oct 1, 2007 | 02:34 PM
fumoazul99's Avatar
Prob a noob question... But is the down pipe the pipe right in front of the flex pipe?
Old Oct 1, 2007 | 02:48 PM
MasterV's Avatar
when you put a test pipe in your car is it still possible to pass emissions?
Old Oct 1, 2007 | 02:52 PM
A4speed's Avatar
ORIGINAL: MasterV
i doubt it, you'll want to get a downpipe and high flow cat. get it from techtonics.
Old Oct 1, 2007 | 03:15 PM
Papachristou's Avatar
it was one of my first mods... bought it cheap.. but it will cause a CEL.. you can put in spark plug anti foulers or i have a CNC machine block from wayne on the vortex but i still got a CEL light intermittently from it....i finally got my APR 1+ flash and they now have a TP file that keeps your CEL from coming on for that reason..
also imade about 9lbs ofboost without it and just at/under 11lbs with it.... less restriction maybe?
it certainly helps spool up and reduces EGTs and weight! the stock cat is heavy as hell! im sure it adds a few HP as well..
one company has a graph on a 2.0t that shows a TestPipe adding about 23 hp and 40+ ftlbs torque! i think thats a little far fetched but i dont know much about the new 2.0fsi engines
Old Oct 1, 2007 | 06:40 PM
AudiCross's Avatar
get a downpipe way beofre you get a testpipe. i hear of people with stock exaust and testpipes and i cringe! y make your car illigal when you could haev the same gains, sund better and be legal. if you haev stock exaust and get a testpipe, sure you lose some restriction, bt the stock downpipe adn exaust is horribly restrictive. just as a rule of thumb, get the legal mods before you start screwing up the emissions. its pointless to go the other way around.
