Drilled or Slotted?
Old May 8, 2006 | 10:14 PM
16w/A4's Avatar
Default Drilled or Slotted?
I am getting brembo rotors for my car and i am wondering what you guys think, they are the same price, should i get the cross-drilled or slotted rotors? I am going for reliable but strong breaks.
Old May 8, 2006 | 10:15 PM
tip5's Avatar
Default RE: Drilled or Slotted?
How about both??
Old May 8, 2006 | 10:19 PM
Papachristou's Avatar
supposedly cross drilled keep em cool while slotted keeps the pad fresh and keeps gas from building up and eliminates fade, also slotted reduces life, i researched a lot and found that slotted doesnt hurt pad life too pad so im going for both check out ecstuning.com they got some cool rotors
Old May 8, 2006 | 10:23 PM
99a4audi's Avatar
ill say slotted
Old May 8, 2006 | 10:24 PM
wood_e's Avatar
CD rotors can't be turned if you warp them. Slotted rotors can be turned.
Old May 8, 2006 | 10:38 PM
badassb5's Avatar
go slotted. drilled ones can crack in high heat if you ever go to the track.
Old May 9, 2006 | 12:36 AM
luvin_the_rings's Avatar
yea, slotted, drilled will crack toward the end of its life, and under high heat
Old May 9, 2006 | 12:39 AM
Cameron's Avatar
Yep, I did the same research and decided slotted was the best idea between the two.
Old May 9, 2006 | 03:44 AM
16w/A4's Avatar
thanks dudes, think ill go slotted, i would have gotten a bbk if i had money but im going for this and good pads, would you recomend mintex? i have heard they are good and am planning on those, what do you think?
Old May 9, 2006 | 03:20 PM
TheJazz7's Avatar
Yeah, Mintex have a good reputation, I'm sure they'd be fine. The EBC Greenstuff pads are popular too, some people buy pads from Hawk also. You'd be good with either of the three.
