drive by wire car
Old Jan 5, 2007 | 06:24 PM
  #21
mudpuppu_94's Avatar
Default RE: drive by wire car
Its like an F-16. When they turn the stick there are no cables or mechanical linkages. Its all electronic
Old Jan 5, 2007 | 08:23 PM
  #22
onepoint8tee's Avatar
ORIGINAL: Pson
ITs what move the TB the older cars have a wire the newer ones use a icm controled (not 100% icm or not) but the dirve by wire has slower pick up then non drive by wires cars. If you have a B5 Drive by wire B6 you do not
Please dont clog the fourms up with information that is false, you obviously have no idea what you are talking about. That goes for you too, tooextreme. Damn. ndbw throtle bodies can be adjusted/aligned. DAMN.
MEMBERS:
If you arent 100% positive about the advice you are lending to other members, then just dont say anything at all. Not only does it make you look bad, it makes the entire site less reputable.
Old Jan 6, 2007 | 04:16 AM
  #23
SAudi's Avatar
The throttle is electronically controlled. when you plant the gas pedal, a signal is sent to the ecu which in turns operate as a motor which works the throttle body. not really a fan of this but so far its reliable on my car.
Old Jan 7, 2007 | 12:46 AM
  #24
ORIGINAL: onepoint8tee
ORIGINAL: Pson
MEMBERS:
Im not trying to start something, but how was the info i gave false? This is what i found on it...
"Like modern aircraft, the accelerator on some Audi models works on the "drive-by-wire" principle. Drive-by-wire throttle interprets pedal input from the driver and automatically adjusts the throttle, turbo boost and ignition timing to deliver incredible response."
Here is the link where i got it...Is this info not accurate? http://www.audiusa.com/audi/us/en2/t..._throttle.html
And here is a little info on F-16. I know that this talks about turning and maneuverability, but it has the same principals of the audi’s drive by wire system.
“The pilot has excellent flight control of the F-16 through its "fly-by-wire" system. Electrical wires relay commands, replacing the usual cables and linkage controls. For easy and accurate control of the aircraft during high G-force combat maneuvers, a side stick controller is used instead of the conventional center-mounted stick. Hand pressure on the side stick controller sends electrical signals to actuators of flight control surfaces such as ailerons and rudderâ€
http://www.af.mil/factsheets/factsheet.asp?fsID=103
Old Jan 7, 2007 | 01:10 AM
  #25
acetrebo's Avatar
mudpuppu 94, I doesnt look like he was talking about you, I dont see him mentioning anything you said, or quoting your post.
Old Jan 7, 2007 | 03:00 AM
  #26
BaconBait's Avatar
ORIGINAL: mudpuppu_94
Only the throttle is electronically controlled.
TexasAudi
Apr 29, 2006 04:28 AM
juju4uofa
Nov 15, 2005 04:59 AM
Peteman187
Apr 21, 2005 11:53 PM
lokdawg
Apr 18, 2005 08:50 PM
01A4Q1.8T
Oct 15, 2004 11:57 PM
