dropping oil pressure...
every now and then while driving down the road, the oil light will flash and beep... new audi code oil, new huge filter, do i need to drop my oil pan or will it wear out, it seems that the longer i have it on the road (just finished head) the less frequently it happens.
Stop driving the car. I had the same problem. You may end up damaging your whole engine.
Whats happened is your oil pump is clogged/dead and its starving the engine of oil, which is why that red light is illuminating. Therefore, you may end up with rods, valves, etc fried.
It'll cost you 8 hours of labor at the audi stealership + new oil pump and PVCs... and thats if you didn't damage any internals. Expect to pay about $1500 USD if no internal damage for the engine flush and labor at the stealership.
PM me if you need more info.
