DV / BOV
Old Aug 29, 2006 | 01:36 AM
  #21
Sleeper's Avatar
Default RE: DV / BOV
I recommend getting an intake rather than a BOV, want it louder than i recommend you getting it chipped. If your car isn't tuned for a BOV don't get it unless you want to run into problems later.
Old Aug 29, 2006 | 01:38 AM
  #22
Jeff's Avatar
Zombie Defense Force
ORIGINAL: audi_pa
next time some says something about a BOV in an audi...i swear...
[sm=shootshoot.gif]
i bet i have herd it a million times more then you lol and i still hate it
Old Aug 29, 2006 | 01:39 AM
  #23
Bondga's Avatar
yeah and did you read the above i already said that I'm getting a SAFMS and tunning it to run MAF less
Old Aug 29, 2006 | 03:18 AM
  #24
Jeff's Avatar
ORIGINAL: Bondga
your doing this all to run a bov???? and i used to take mine off all teh time and run it as a bov
Old Aug 29, 2006 | 03:23 AM
  #25
18T's Avatar
18T
here we goo...
The Audi turbo system is a closed loop system by which all unused boost that is spooled during off throttle and gear shifts must be re-routed within the system; it cannot be vented to the atmosphere due to the dependence on the MAF and ECU to properly read and interpret air flow dynamics within the intake tract. Therefore BOV's (Blow-Off Valves) are not used because they create a rich air/fuel condition (i.e. less air to fuel ratio) which will damage the catalytic converter, create soot on the exhaust pipes, and cause occasional misfiring (due to the purged air) which will result in ECU miscalculated timing adjustments and other errors.
For Audi closed loop turbo systems, a BPV (By-Pass Valve) or DV (Diverter Valve) is needed to recirculate the purged air and keep it within the intake tract.
Old Aug 29, 2006 | 04:02 AM
  #26
evoic's Avatar
ORIGINAL: 18T
here we goo...
And if you're removing the Cat, I'm sure it's still a problem, but one less component to worry about?
Old Aug 29, 2006 | 04:06 AM
  #27
SouRce4's Avatar
whats the difference between Bypass valve and DV?
Old Aug 29, 2006 | 04:07 AM
  #28
Sleeper's Avatar
BPV = DV
Old Aug 29, 2006 | 04:12 AM
  #29
SouRce4's Avatar
makes sense. any1 using any of the hybrid valves? if so are they good :? and where can i find one?
Old Aug 29, 2006 | 10:41 AM
  #30
smokeU's Avatar
wow...
