Dynamic headlight range control defective
Old Oct 26, 2006 | 05:06 AM
bones's Avatar
Default Dynamic headlight range control defective
Got a 2004 A4 1.8.. light for the Dynamic headlight range control is on, anyone ever experience this? It says in the book to take it to the dealership and doesn't specify any troubleshooting tips. I already booked an appointment with Audi since the car is still under warranty. But I would like to try to do it myself it it's an easy fix (ie. fuse, etc.) instead of wasting a day at the dealer. If anyone's ever experience this, what was the problem? Is there a fuse for this? Or is is it something major where the whole headlight will need to be replaced? Anything I can check on my own?
Thanks in advance.
Old Oct 26, 2006 | 12:54 PM
a4sport's Avatar
Default RE: Dynamic headlight range control defective
I had the light too. When I took it to the dealer for a key programming, they cleared it for free. Now they adjust like they should. You can see it when you start the car. Pretty sure you'd need VAG to do it yourself.
Old Oct 27, 2006 | 12:19 AM
dankhound's Avatar
There is a reflash to correct some issues with the system where a fault light is activated when there is no fault in the system.
Old Oct 27, 2006 | 03:40 AM
bones's Avatar
The lights don't auto adjust, so I'm guessing there's an actual problem with the headlights. Thought it might be a blown fuse or some other easy DIY fix. I'm taking the car in on Tuesday so they can fix it.
Old Oct 27, 2006 | 11:00 AM
a4sport's Avatar
I honestly don't think it's your lights. It's not like you're going to need to replace them. I wouldn't think so anyways. Just like we said above, it should just be a reset and all will be fixed.
scatterbuzz
Jun 3, 2015 01:25 PM
marblehead
Jan 8, 2015 10:32 AM
BMackenzie
May 6, 2011 12:40 PM
Dr!ven
Feb 11, 2011 10:58 AM
jack112
Mar 10, 2006 06:16 PM
