Dyno-scan software for Palm
Old Apr 12, 2007 | 08:54 PM
daesharacor's Avatar
Default Dyno-scan software for Palm
Hey guys.
I have some software for my palm made by Auterra called Dyno-scan. It's an interface with the OBDII port on any car, where you can access tons of interesting stuff, like all your sensor readings (Throttle position, RPM, speed, intake air temperature, water temp, timing, air flow rate, o2 sensor readings, etc etc, i dont have the list with me now.) in realtime, as well as checking and clearing DTCs. It's pretty damn cool if you ask me, and a very useful diagnostic tool. Anyway...
One of the cooler features is the ability to make dyno runs. You enter in all the requisite information (Weight, Gear Ratio, Tire Diameter, Temp, Elevation, Humidity, Pressure, etc...) and it is able to compute your horsepower and torque based off the sensor readings of speed and rpm.
Now, I'm not saying it's perfectly accurate, but it looks pretty good and I thought I'd share my results with the class and see if anybody else has ever used this, or what they think about my results.
Either way, accurate or not, it should be a good benchmark to show everyone my actual gains when i chip, go ko4, etc
P.S. - I made four runs and averaged them, since the road probably wasn't exactly flat, I went back and forth.
Edit: While I'm at it, here were my stats...
Max Torque: 146@4700ish
Max HP: 144@5600
Old Apr 12, 2007 | 09:01 PM
CRAZYHAWK's Avatar
Default RE: Dyno-scan software for Palm
How did you determine 31.25 Hg at 1000 Ft.?
Old Apr 12, 2007 | 09:03 PM
We have a barometer at my house, and my dad's a pilot and has charts for the elevation.
Old Apr 12, 2007 | 09:27 PM
Jeff's Avatar
Zombie Defense Force
very nice. its good to see this kind of software making its way to the audi comunity. now if we can just get some free software that will allow us to tune
Old Apr 12, 2007 | 10:09 PM
evoic's Avatar
I need the CAN-BUS port version !
Jeremy@ConceptDub
Apr 21, 2025 07:55 PM
livemsn22
Jan 4, 2014 08:12 AM
moneymadness
Dec 14, 2011 12:00 AM
moeron7
Apr 15, 2008 05:31 AM
