ecu help fast
Old Jun 4, 2007 | 12:32 PM
germancarmaniac's Avatar
Default ecu help fast
I am thinking about buying a ko4 and ecu today. The problem is that my car has a 8d0-907-557p in it and the other ecu has a 8d0-907-558-m. The difference in the cars is that one is a 99.5 quattro manual and the other is a 98 quattro auto. I work at a dealership and was wondering if I can even use this ecu or do I need to reprogram it. And if i reprogram it will it mess with the chip. Please help me out, Im kinda lost on this subject. Also, if I have to reprogram it, does anyone know how to do that? thanks
Old Jun 4, 2007 | 12:50 PM
techbod's Avatar
Default RE: ecu help fast
the automatic tranny has its own ECU so wont be effected by the engine management ECU so I cantthink ofany problems
Old Jun 4, 2007 | 12:58 PM
techbod's Avatar
there are 2 system types
Motronic M3.2/3.21 this one has 5 connections in the rear and 96 pins in banks 12 - 24 - 24 - 24 - 12
Motronic M3.8.2 this one has 2 which has 59 pins
Old Jun 4, 2007 | 02:18 PM
so will it work?
Old Jun 4, 2007 | 02:30 PM
akielb's Avatar
Yes just verify softcoding with a vag-com - if it is set-up for Auto then you will need to reset it for manual. basically check your softcoding in your current - then change the new ECU to that.
crappazappa
Mar 11, 2009 03:10 PM
S4RiddeR
Sep 1, 2007 02:39 AM
bmwtoaudi
Jan 15, 2007 10:32 PM
dozentrio
Aug 31, 2006 04:23 PM
