ECU replaced.. what to do about chip?
Old May 6, 2006 | 11:06 PM
Dobie337's Avatar
Default ECU replaced.. what to do about chip?
I recently had to have my ecu replaced and I have a K04 and did have a GIAC chip on my old ECU but the new ECU is stock. Is it possible to take the chip out of the old one and put it into the new one? any suggestions?
Thanks
Old May 7, 2006 | 12:59 AM
Audi42005's Avatar
Member
Default RE: ECU replaced.. what to do about chip?
was the chip soldered in or flashed? if it was soldered in the you should be able to take it out and put it in your new one.
Old May 7, 2006 | 01:02 AM
Jovian's Avatar
The chip "should" be reprogramed so it works better with the K04. GIAC has specific K04 profiles that run better. You can run your old chip but it wont be as fine tuned.
I suggest you take it to a shop that deals with GIAC and give it to them and tell them you want a K04 profile.
Old May 7, 2006 | 11:12 AM
JettaRed's Avatar
Contact GIAC or the shop that did the original chip/flash and explain what happened. You'd probably have to pay a labor fee to install the chip or do the flash, but I would think you wouldn't have to buy the software again.
Old May 7, 2006 | 02:06 PM
onepoint8tee's Avatar
ORIGINAL: Jovian
Pretty sure that he is well aware of that... And Im pretty sure he is fucked if it was a flash.
Old May 8, 2006 | 03:49 AM
BadLuckAudi's Avatar
maybe if he took the flased ecu back and showed them that he had it done there they might be kind
mitch's sline
B7 Models
Oct 4, 2008 07:57 PM
s4noob
9
Jun 24, 2008 02:41 PM
ricehead
Nov 4, 2005 10:59 AM
