ECU upgrade question
Old Aug 24, 2006 | 04:50 PM
bluesnapper's Avatar
Default ECU upgrade question
Is there any way to tell by looking if an ECU has been "chipped" or upgraded. I bought my 1.8t used and am just curious. It seems to be a little fast for being stock and I have no way of contacting the previous owners. I'm the third owner. Is there anything on the circuit board of the ECU that is visually noticeable?
Old Aug 24, 2006 | 04:53 PM
InsaneHatter's Avatar
Default RE: ECU upgrade question
if you are 99.5 and ealier, then you can open the ecu and physically see the chip, otherwise no.. sometime tuning companies label the ECU as well.
you could also get a boost guage,
Old Aug 24, 2006 | 04:58 PM
I have a 99.5 Is there any trick to opening the ECU? Any percautions I should take?
Old Aug 24, 2006 | 06:14 PM
onepoint8tee's Avatar
Remove the weather stripping and slide out the cover that goes over your brake fluid resevoir and battery etc. and the case for the ecu will be on the drivers side corner. Remove the screws and take lid off. You dont need to disconnect your battery as long as you arent disconnecting the ecu.
Casey_A41.8t
Mar 20, 2010 03:04 AM
lp2003
Jul 7, 2007 08:02 PM
eurokid
Apr 29, 2007 08:36 PM
sdsteez
Mar 22, 2007 01:19 PM
Byan
Feb 13, 2005 08:51 PM
