View Poll Results: Which Engine would you buy as a replacement for your old one?
$1000 running 115k miles engine
0%
$500 broken timing belt 60k miles engine
0%
Voters: 0. You may not vote on this poll
which engine to buy? broken timing belt for $500 or running for $1000
Old Mar 4, 2011 | 10:39 AM
djshyc's Avatar
Smile which engine to buy? broken timing belt for $500 or running for $1000
I have a B5 A4 2.8 AHA. I bought it with the headgasket blown. The owner said he ran it for only a very miniscule time when he saw the steam cloud come out of the tail end. So I took a chance on it. When I dug into it I found the pcv tubes and spark plug wire sheaths melted.. It musta got real hot!
I went for replacing the head gaskets. Simple enough.
Had the heads machined & replaced gaskets and a few other little things while I was in there. Got her back together and then heard a tapping in the bank 1 head and also found that bank 2 cylinder 5 has bad rings. Good compression and leak down results in all but cylinder 5 leaking past rings.
So Im looking to replace this engine.
Question here is what route to go.
I found a complete running engine with 115k miles for $1000
Found another one with 60k miles BUT has a broken timing belt for $500
What would you do? Any opinions or ideas are welcome. Thanks...
MBliz
Mar 10, 2008 12:12 PM
thepirate
Dec 16, 2007 11:51 PM
jrock
Nov 27, 2007 04:02 PM
ttoo cool
Mar 9, 2007 07:09 AM
