engine code p0411
Old Sep 6, 2006 | 09:45 PM
audi4s's Avatar
Default engine code p0411
I had this code come up and it says it's the secondary air injection system incorrect flow. Can anyone help me out here? I cleared the code but I'm not really sure what it means.
Old Sep 7, 2006 | 03:17 AM
dankhound's Avatar
Default RE: engine code p0411
On cold starts a pump pumps air into your exhaust to speed up catalytic converter warm up. This is the function of the secondary air injection system. It contains a pump(to pump air), a combi valve to divert air to the exhaust, and a control valve to decide how much air is pumped to the exhaust. The control valve diverts vacuum to the combi valve to open or close it. This is done from an electrical signal from the ecm. The combi vavle opens when vacuum is applyied. This allows air into the exhaust. The pump is turned on by the ecm to pump the air to the exhaust. Assuming the pump and control vavle are operating to specs, which may not be the case, the primary cause is a dirty or plugged combi valve. They have carbon buildup that prevents airflow. The combi valves are located on the rear of the head. It has one big pipe that goes to the pump. And another smaller vacuum line that goes to the control valve.
Billions
Jul 31, 2016 02:03 PM
74bronco302
Jun 4, 2010 03:22 PM
A4 2000
Aug 28, 2009 12:28 AM
afstud6900
Oct 27, 2008 04:00 PM
Renci
Dec 23, 2007 06:52 PM
