Another P0411 cel code
Old Aug 25, 2009 | 02:21 AM
A4 2000's Avatar
Default Another P0411 cel code
(Secondary air injection incorrect flow detected)
O.k. so I know my secondary air pump is running fine. The only vacuum line that looks bad is the long one that runs in front of the timing belt cover and connects to the BPV. Could this be a cause for the code? Thanks in advance.
Old Aug 25, 2009 | 08:26 AM
mastvadz71's Avatar
Member
what motor do u have ?
Old Aug 25, 2009 | 11:40 AM
Tweaked's Avatar
If it's a 1.8T, that's your diverter valve line. Replace it with the Audi updated hose, but thats likely not the issue. It's usually one of the annoying check valves or solenoids.
Old Aug 25, 2009 | 06:37 PM
A4Cragman's Avatar
Could be the relay as well. Those are pretty notorious for sticking after time and not opening when they should, look into a new one of those if you can.
Old Aug 27, 2009 | 02:15 AM
A4 2000's Avatar
It's a 1.8T ATW
So there's actually a few of them I've seen. So Is this like a kind of trial and error thing?
I want to look into that too. So are these pretty much all possible causes if the pump is running fine? Is there a chance that maybe the sensor that's sending the code could be bad? I have no idea where that would be located though.
Thanks everyone for the help.
Old Aug 27, 2009 | 02:33 AM
A4Cragman's Avatar
You'd have other codes if it was the sensor. If I remember correctly, it's the O2 sensors that send that code. Basically, the pump throws in some extra air on a cold start to the exhaust mani to balance the fuel trims and so the pre cat O2 sensors register the extra oxygen and tell the computer to use less fuel so its not running rich while everything is getting up to normal operating temperature (at least thats how I understood the mechanism when it was explained to me) so if it were the sensor that was bad, you'd have a CEL for a bad O2 sensor as well. Other than that, yes, these are more or less all of the things that would throw that.
Vac line tubing is relatively cheap ($6.95/3 feet on ECS if I remember right) or silicone vac line is even cheaper, but I dont remember the good site for that so you might research that if you want something a little more durable than the stock, braided rubber line. But go through and replace all the vac lines, especially the DV line Tweaked mentioned, after that, troubleshoot the check/combi valves, and then replace the relay if it's still throwing the code (I say leave the relay to last cuz thats the most expensive component, ~30 bucks so work with what is cheapest first IMO)
Old Aug 27, 2009 | 10:03 PM
A4 2000's Avatar
O.k., so I'll probably be getting those vacuum lines first and then move on from there. Thanks for all the help! I'll make sure to post up any results.
Old Aug 28, 2009 | 12:28 AM
A4Cragman's Avatar
NP, good luck
knowledge 101
Jul 3, 2012 03:55 PM
intake
Mar 21, 2008 06:58 PM
cantdrive55
Dec 4, 2007 05:36 PM
madridlover
Jul 3, 2007 08:45 PM
ewaardo
Oct 8, 2006 01:46 PM
