Engine codes: p1128 and P1136
my check engine light came on and when I took it in, it gave this engine codes P1128 and P1136. They were saying it had to do with the fuel system? could someone tell me what these codes are and how to fix them?
02' 1.8T FWD Sport 5MT.
Revo Stg2 w/ Siemens 380cc.
ER TP.
Ebay SS(So worth $40)
Forge007.
APR TIP.
K&N CAI w/ Matt-shield.
Magnaflow Exhaust.
ECS Snub mount.
Painted Lowers w/ s4 door blades and Lip spoiler.
edit : i dont deal with mods
ER TP.
Forge007.
APR TIP.
Magnaflow Exhaust.
ECS Snub mount.
Could be:
Intake Air leaks (false air)
Check Heated O2
Check mass airflow sensor
Fuel pressure regulator
Fuel injectors.
Those are the possible causes. You may want to get a Bently/Haynes for all the proper test procedures if you are going test these yourself.
Air leaks and MAF are easy to check for. You can try to Clean the MAF, and see if the codes come back or not.
Check Heated O2
Fuel injectors.
