Engine codes: p1128 and P1136
Old Jun 22, 2007 | 10:30 AM
razak42's Avatar
Default Engine codes: p1128 and P1136
my check engine light came on and when I took it in, it gave this engine codes P1128 and P1136. They were saying it had to do with the fuel system? could someone tell me what these codes are and how to fix them?
Old Jun 22, 2007 | 11:02 AM
chitownA4's Avatar
Default RE: Engine codes: p1128 and P1136
http://www.bentleypublishers.com/tec...l=&ticket=none
try here
Old Jun 22, 2007 | 11:05 AM
chitownA4's Avatar
17536-P1128-Long Term Fuel Trim mult.,Bank1 System too lean
17544-P1136-Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
Old Jun 22, 2007 | 11:11 AM
chitownA4's Avatar
i would get that checked out asap..running lean=bad news bears
-check maf(clean it, replace airfilter)
-check o2 sensors
-look for boost leaks
Old Jun 22, 2007 | 12:06 PM
acetrebo's Avatar
What year and engine is your car?
Old Jun 22, 2007 | 12:27 PM
techbod's Avatar
02' 1.8T FWD Sport 5MT.
Revo Stg2 w/ Siemens 380cc.
ER TP.
Ebay SS(So worth $40)
Forge007.
APR TIP.
K&N CAI w/ Matt-shield.
Magnaflow Exhaust.
ECS Snub mount.
Painted Lowers w/ s4 door blades and Lip spoiler.
edit : i dont deal with mods
Old Jun 22, 2007 | 12:29 PM
acetrebo's Avatar
Wrong sig mate, look at post number one, no sig.
What you posted if from chitownA4, he's not the one with the problem.
Old Jun 22, 2007 | 12:34 PM
techbod's Avatar
oops but why not try to answer the question but will be interested in the result
Old Jun 22, 2007 | 12:39 PM
razak42's Avatar
it's a 1999 A4 avant 1.8 Turbo
Old Jun 22, 2007 | 01:01 PM
acetrebo's Avatar
Could be:
Intake Air leaks (false air)
Check Heated O2
Check mass airflow sensor
Fuel pressure regulator
Fuel injectors.
Those are the possible causes. You may want to get a Bently/Haynes for all the proper test procedures if you are going test these yourself.
Air leaks and MAF are easy to check for. You can try to Clean the MAF, and see if the codes come back or not.
